spring washer for release bearing
Hi there,
I have a 1978 911 SC and I am replacing clutch disk, pressure plate and release bearing.
In the Bentley manual it shows that the spring washer smaller diameter should be against the pressure plate. And
Haynes manual
Bentley manual
on Haynes manual it shows that the springs bigger diameter is facing the pressure plate.
Can anybody, please help me to solve this problem.
Take care.
Boris
Haynes manual
Bentley manual
Take care.
Boris
Boris, you could check the order of parts from factory parts catalog that you find here:
https://www.porsche.com/usa/accessor...artscatalogue/
With little searching you probably find the factory service manuals on the web. I only have for 3.2.
@radetic
skip forward to 5:30, i think this may answer your question, he did it wrong the first time... https://www.youtube.com/watch?v=WMny...wZ3_g&index=21
Boris
