Early 911 Electrical Issues- Part III-Final
Ladies and Gentlemen:
While checking my charging system I had the oil pressure/oil temperature gauge out of the dash, and I was trying to find out if I had 12 volts between the blue wire (D+/61) and the red with black stripe (switched +12v). I turned the ignition key on and . . . no voltage, but plenty of smoke and a nice sizzling sound.
When the smoke cleared I found that the red wire with black stripe had melted most of its insulation, and had arced against the brown ground wires that daisy-chain across the back of the gauges. Some of the sender wires had also arced and melted together.
To make a long story short I have located a supplier for the original german brass connectors and rubber sleeves, and original german plastic-covered wire, including the correct spiral black stripe. Check out http://www.ynzyesterdaysparts.com/ for - they manufacture an RSR harness so I figured they know their stuff. I couldn't bring myself to use different wire and AMP Faston connectors- this would make future diagnosis difficult, and also serve as an acknowlegment to future generations of my ham-fistedness.
Anybody have a guess as to why the arc welding? Only thing I can think of was that I disconnected the positive lead to the trunk lights so they wouldn't bleed off battery voltage while I had the hood open to charge the batteries. But this does not appear to be in the same circuit with the lights. Maybe there was some chafed insulation somewhere.
I now look forward to removing each gauge, marking the back with a permanent marker, putting a wire marker on the wire, and then fabricating a new mini-harness for the backs of the gauges. Fortunately the heater is out of the trunk pending my fuel cell install so I can access the gauges from the back side. Anybody have any advice, other than to not do it again?
Thanks in advance,
John
Thanks in advance,
John
Yeah, don't do it again! I think you are pretty much onto something with the chafing idea. That German insulation gets fairly brittle with age as well.
I figure, you have a '71 911, with some hard miles on it (racetrack)...there's a lot of vibrations, etc. going on in there...so I think you've answered your own question as to why the fireworks?
