Numeric Racing Performance Pedals
Preorder on our website: Pedal Preorder!
Key features:
-Patented Grip. Our patent pending hex design provides outstanding grip and a clean look.
-Smoothest action Gas Pedal out there. Our gas pedal implements ball bearings on the pivot instead of a thin plastic pivot on the stock gas pedal.
-Most Responsive. This is due to the all stainless steel hardware and therefor removes any slop or "play" felt in the gas pedal.
-Fully ADJUSTABLE! Yes, we prioritized adjustability in the design of these pedals without sacrificing an appealing appearance. The gas pedal mount that is bolted down to the car floor is slotted and gives that adjustability based on the driver preference to move the gas pedal closer or further to the brake pedal, aiding in heel-toe based on your preference. The gas pedal can also be adjusted to be moved closer to the driver or further with an adjustable rod on the backside of the pedal. The bottoming out for full throttle is also critical in these gas pedals, so therefor we also had to make an adjustable bottoming stop so that the throttle cable won't get damaged.
-OEM Fitment. Is installed just like OEM but gives you the aftermarket performance.
They are available in Black or Aluminum and with or without the numeric logo.
Watch a recap video below!
Watch here:
