Interior Electrical question
Hello. Just purchased my first 911SC. It does not have any interior lights (dash). On a side note, the aftermarket radio does not power up either. All exterior lights are functional, as are all of the gauges, heater fan, A/C fan, and sunroof. I have checked the fuses in the main panel up front, and they all appear good. Any clues? I can't believe that all of the individual bulbs could be burnt out.
1. rotate each fuse back & forth while spraying Caig at the terminals, then check for voltage w/mutimeter at downstream terminal
2. check each ground, or better take apart and clean - do the trans. gnd too to make sure a worse problem is not impending
Not sure rotating the fuses is going to help - the dash lights are not fused at all. Power comes off the back of the headlight switch. I would start there, and see if anything is fried. Take a look a this thread on how to add a fuse to the circuit, I think this will help: http://forums.pelicanparts.com/porsc...tallation.html
Mark
Mark
