Auto Door lock
I am presuming that the mechanical action with the switch is fine (the door cylinder rotates smoothly).
Second, does the passenger door unlock cause both doors to unlock? In theory unlocking either the passenger door with a key or drivers door will unlock the other.
Failing that, there is a little microswitch like this:
Big honking plug that goes into the door harness. The microswitch toggles up and down (the greenish part on the pic) with movement of the cylinder which causes the unlock/lock to occur. The switch could be damaged, it is not that hard to get to once you take the door cards off (which means the handle, door pocket etc etc). and removing the door handle.
Looking at the wiring diagram, it is also possible that one of the wires going from that switch to the chassis has been damaged. From my records there are three wires going to the microswitch - Brown/Blue, Brown/Green, Brown (ground) and I don't know whether it is the Br/Bl or Br/Grn that is unlock, but it is one of those two that could be perished right at the point where the action of the door opening and closing may have fatigued the wire. You can see the loom (black plastic tubing) from the door to the chassis....check if any of them look cracked or there are wires hanging out. That could also be your problem.
I doubt if it is the central lock relay...and I am presuming that the central lock/unlock button in the centre console also works properly?
Hope this helps
Cloggie
Thanks for all the help!
