Keyless Entry Issue
Hi Everyone,
I’m planning to buy a second hand C4S 2013 but there is an issue with the car with its keyless entry system and I’m trying to predict the repair cost to be taking under consideration before purchasing the car. The issue is as follows:
When I try to push the button in the both to lock/unlock the car the remote blinks but nothing happens. However, I’m quite confused to diagnose the issue since the car starts normally with the dummy key and the key fob blinks whenever I push the button in the handle. Does it mean that the keyless entry system is partially working? Or it means that the handles needs replacement? Or the main unit for the keyless entry needs a replacement?
The issue is in both doors.
Thank you in advance for your support.
