911 Forum 1964-1989
993 window switch issue
Old May 19, 2020 | 12:30 AM
912E's Avatar
912E
Default 993 window switch issue
Hello friends,
About 10 months ago, my passenger window switch on the driver's side started working slower than the d/s window switch. I never did anything about it. 3 days ago, both driver's side switches died out. Thing is, the fuse is fine, the switches are good (I tested them on p/s for and all 3 switches work there). The wires are hot because if I unplug either switch, the switch in the p/s door stops working because I assume the circuit is broken. It can't be the motors because the passenger side window works with the p/s switch.
Any other ideas of what it could be?
Old May 21, 2020 | 09:20 AM
912E's Avatar
912E
Any thoughts? Is this in the wrong forum?
Old May 22, 2020 | 12:27 PM
911PERVY's Avatar
911PERVY
Yes, Im afraid so
Old May 23, 2020 | 06:02 PM
Edward's Avatar
Edward
Addicted Specialist
Try swapping in the pass side switch with one of the driver's side ones and see if that helps: if better, then replace the switches ...cheap fix. If same, then likely dead motor, ugh.
Edward
