Ordering Custom Wheels - Help with sizes?
Hey guys, I am ordering some custom wheels for the first time and overwhelmed with the information. I'm debating on either going:
1) 16x7 front 16x8 rear 205/55 front 225/50 rear
2) 16x7 front 16x9 rear 205/55 front 245/45 rear
I like the look of option 2 more but I'm a little concerned about tire options for 16x9 rears. Does anyone run 16x8 rear? Will the 9 be that much more beneficial?
Also, can someone tell me what offsets I would need for the above sizes for the car to look "flush" when lowered? I don't mind if I have to roll the fenders. When placing my order I am not sure what I need to put as my offset.
I would like to avoid running spacers and this is the type of fitment I would like (http://forums.pelicanparts.com/uploa...1442948769.jpg)
Thanks in advance!
Thanks in advance!
Different size tires have different "Roll Out" The over all finished width of the tire on the ground. My custom 8" rears finished at 10" +. I was worried that the passenger side rear might rub the oil lines if I went with 9".
I was also wanting the right offset that allowed me to get as close to the fender (and not rub) as possible. I personally did not see the need to go to 9" rears. Others have tho.
My rear offset is et 10 on an 8" rim running a 255/40.....I could not be happier.
Thanks, AG81. I placed an order for the 7/8s
Going to be running 16x7 +23 front and 16x8+10 rear wrapped in 205/55 and 225/50 respectively. Will post pics when the wheels come in and are mounted on the car but after digging around the archives of rennlist/pelican this should be flush.
I would've thought a 255/40 would be big of a tire on an 8" rim?
It works great..... looks very appropriate. I had previously run 225/50 on an 8 for my rear tire.... those calculate out as 24.9 dia, 8.9" roll out, 4.4" sidewall, 78.1 circumference....... The 255/40 calculate out as 25.0 dia, 10" roll out, 4.0" sidewall. 78.6 circumference
It works great.
the wheel does distort the carcass
on an 8,5 a 255/40 should measure out to ~255/41, w/ 826 revs/mi, the rolling radius will depend on chassis wt & tire pressure but the rolling radius will be ~12.2" the std radius is ~12.5" the difference in those 2 #s is called the tire deflection
roll out is how far the axle travels when the tire is rolled it correlated to the revs/mi and can be done either loaded or not
