911 Forum 1964-1989
MFI Stack size
Old Mar 6, 2004 | 11:34 AM
GrantG's Avatar
GrantG
Default MFI Stack size
I have a 2.7RS type motor with MFI. It has the black plastic intake stacks common in 73 with part number 911.110.316.1R molded into the second stack on each bank (on the right side of each left and right second stack). I was hoping that someone who knows whether their MFI comes from a 911T, E, S, RS could tell me if they match this part number. I'm trying to discover if it's the larger or smaller version. I was told that it was the smaller (found on T and E cars) but then bored out...
This part number is too old to be found with the PET.
Thanks,
Grant
Old Mar 7, 2004 | 04:57 PM
Brian 96C2's Avatar
Brian 96C2
Grant,
That is a 'T' part number.
Old Mar 7, 2004 | 05:10 PM
GrantG's Avatar
GrantG
Thanks Brian!
Old Mar 7, 2004 | 10:27 PM
pwd72s's Avatar
pwd72s
For what it's worth...the number on my car's right (as you look at the engine) stack reads: 911.110.312.1R. Original '72S with the VIN# 911 230 1556. My understanding is that the stacks of the 2.4 S and the 2.7 RS were identical in bore. Keep in mind that "my understanding" has been wrong before, so it could be now...
Old Mar 7, 2004 | 11:00 PM
GrantG's Avatar
GrantG
Thanks!
Old Mar 7, 2004 | 11:05 PM
Brian 96C2's Avatar
Brian 96C2
Grant and Paul,
Here is an interesting discussion on the Early S site about the confusion of numbers on MFI stacks.
MFI stack part number discussion
Old Mar 8, 2004 | 12:06 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Gents:
The only true way to know what you have is by measuring them at the bottom flanges.
Thankfully, the stacks are not hard to remove & replace.
Old Mar 8, 2004 | 12:37 AM
Brian 96C2's Avatar
Brian 96C2
Which I believe for a 72-73S/RS is 38mm at the bottom of the stack where it meets the top of the throttle body.
7 Porsche Models That Have Aged Like Fine Wine
Old Mar 8, 2004 | 01:57 AM
GrantG's Avatar
GrantG
Thanks again Steve & Brian!
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
