How to Identify Low Side AC Fitting?
I am adding refrigerant (R134)to my AC system and am confused on which service fitting to connect to. Compressor is a Sanden rotary and the Service fittings are lableled "SUC" and "DIS".
Thanks in advance.
Thanks in advance.
Low side is port labled "SUC" As in Suction and "DIS" discharge. You really should use a manifold guage set for charging so you can monitor both sides, especially w/ the higher pressures R134a creates.
The low side is also connected to the evaporator and the high side to the condenser (the thing mounted on your trunk lid)
I agree with DK, get yourself some manifold gages to properly charge any system.
