RS Door Cards
RS Door Cards
I have an issue with my rennline door cards...they are an inch off at the speaker hole location. When measuring the bottom of the speaker to the bottom of the card in the stock panel is 2 in and is 3 in on the rennline panel. My question is there something I’m missing here on variability of the speaker location in 3.2 Carreras. They don’t line up at all and rennline says their panel is spot on for a factory location.
The speakers fit perfectly in the stock panel
What am I missing???
OU, I found the exact same issue........... I then used my factory panels as a templet for some 3/32" thin birch plywood.
Making my own panels (knowing I was going to recover them anyway) didn't bother me.
How strange...are the g50 GBody cars different from everything else I wonder.
mount speakers to the panel, not to the door... that's how the factory did it. does that allow it to work?
not sure where they got their templates, i've installed the AppBix panels on 4 cars and they fit perfect.
speakers are mounted to the door...the speaker hole in the door card is off almost an inch
