Am I Bent?
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I was poking around at the car tonight, trying to figure out the
cause of the occasional clunk I hear from the front. The sound
is kind of high-pitched, and may have been loose tools in the
trunk.
Or not.
A couple days ago, I thought the f/l tire looked a little over-cambered,
but the car was parked on a small rise, so I figured it was the angle
in which it was setting. Tonight I looked at it closer, and I think I
have an 'issue'
http://www.vintagebus.com/gallery/image/10453.JPG
For S&G, I played with the alignment adjustments on the top of
the shock. I brought it all the way out to the edge of the adjustment
hole, which is where you see it now; yes, I had more negative camber
than that!
For reference, Friday afternoon on the way home from work, I hit a chunk
of metal laying in the road - no way to avoid it - at about 25-35 MPH.
I don't have any shimmies or shakes. There's been a slight pull to the right
when driving in a straight line, but it's been doing that since the previous
failed alignment.
There is no play in the wheel at all, and the boot around the ball joint is intact.
I did a cheepie runout test of thewheel, using a screwdrive setting on a milk
crate, while turning the car while it's in the air, and there's no discernable
wobble.
So, what do you guys think needs replacing?
I already had my re-alignment scheduled for tomorrow - should I just cancel,
or should I have the shop see what they can do?
Thanks!
trunk.
Or not.
have an 'issue'
than that!
failed alignment.
wobble.
Thanks!
Sounds like it's time to upgrade to a 935 suspension!!
I feel for you Thom, I would love to buy you a beer one day and hear your Porsche experience first hand.
Best of luck
Chris
Best of luck
Chris
Originally posted by Chris Martin:
<STRONG>Sounds like it's time to upgrade to a 935 suspension!!
</STRONG>
I've seen the aftermarket setups like TRG and others make, and it looks cool, but I'm afraid it would be even more fragile for street use!
<STRONG>
</STRONG>
Thanks! I look at is as learning to build a 911 from scratch. Maybe one day when I get all these little issues dealt with, I'll start on that 3.8L monster motor...
</STRONG>
<STRONG>
</STRONG>
