The factory didn't produce the Turbo-Look model until1984. If the car has turbo flares, then it was customized. You should check the work done to attach the flares.
thank you, the owner is a long time friend and doesn't cut any corners when it comes to his toys. He daily a 2019 M5 and has a 997 with over 1000 hp set up. He probably customized the car to look nice like this. We'll see.
