911 Forum 1964-1989
Speedometer Gear Identification
Old Nov 12, 2019 | 08:14 PM
Kerry Chadderton's Avatar
Kerry Chadderton
Default Speedometer Gear Identification
Hello All!
I have an unusual problem. I have a 1985 Carrera. The odometer stopped working, which is no surprise. I took the speedo apart and found half a gear with the consistency of a gummy bear. This is the fourth speedo/odometer that I've repaired. It's usually very straightforward. I normally have two solid pieces, or a single gear with three teeth missing to deal with. I can not count the teeth on this unit and I'm afraid to touch the remainder of the gear. Can any of you identify the proper gear and tooth count to order? When I do a search on Pelican Parts I get every possible gear available. I don't know....
Old Nov 13, 2019 | 03:52 AM
911PERVY's Avatar
911PERVY
Cant you count half the the teeth then double it?
Old Nov 13, 2019 | 04:56 PM
Kerry Chadderton
I suppose that I might be successful at that. I was just hoping that someone knew off the top of their head. I'll get my magnifying glass and pointer out. Thanks....and SEXY 993 you have there mate!
Old Dec 7, 2019 | 01:00 PM
Kerry Chadderton
Just in case anyone asks the same question that I did: This is the Odometer Gears OD 20x30 gear.
FWIW - www.odometergears.com is the bomb! Great product. Great instructions. Many applications.
