I have a 1989 Carrera with power seat on the driver's side. When trying to move front-back, the left side of the seat moves fine, but the right side doesn't even try to move. Can anyone point me in the right direction as to what could be wrong and how to fix it?
Ckeck the motors. Usually there is one motor per function. They are ususally interchangeable so that you can swap positions to see if that is at fault.
Thanks guys, it turned out that the flexible shaft going to the right side adjustment screw was just pulled out a little. I popped it back in and it's working fine now.
Hi Slantnose. My 2018 colorado has the same problen but my drive shaft for the seat is snapped for the right side if sitting on the seat.. Do you happen to know if you can just replace this drive shaft? and Where to get it by chance?
