911 Forum 1964-1989
3.0 Carrera engine...
Old Mar 11, 2002 | 03:49 PM
Michael Ghia's Avatar
Michael Ghia
Cool 3.0 Carrera engine...
I'm looking at buying a 3.0 Carrera 1976-77 motor. Is there anything which I should know about this particular engine, any nasties?
Mike Ghia
Old Mar 11, 2002 | 05:42 PM
Bill Verburg's Avatar
Bill Verburg
Post
Just that they are over a quarter century old and prone to all the usual ailments associated with advanced age. Mine snapped 3 head studs at ~108000 mi/21yrs. Other than that and the expoloding air box it was a pretty bullit proof engine.
Old Mar 12, 2002 | 01:24 PM
Michael Ghia
Cool
Thanks Bill.
Thats great.
Old Mar 13, 2002 | 01:32 PM
Hunter's Avatar
Hunter
Post
Well, 3.0 engine is a reliable engine.Try to see the engine running before buy at a stand or drive it if possible.Check for compression,for smoke white or blue as this a bad sign,crank end play,oil leaks.If you find a engine that it will need a full rebuilt then maybe it is better to go for a 3.2 engine...
Regards,
Hunter 993TT
Old Mar 13, 2002 | 06:27 PM
Dana Drury's Avatar
Dana Drury
Question
[quote]Originally posted by Hunter:
<strong>Well, 3.0 engine is a reliable engine.Try to see the engine running before buy at a stand or drive it if possible.Check for compression,for smoke white or blue as this a bad sign,crank end play,oil leaks.</strong><hr></blockquote>
I thought that some blue smoke on ignition was okay because oil was still in the case and thus was burned on start up. I know that my 3.0l Carrera smokes for about 10 seconds on start up (blue) and then that clears away. It may smoke longer if I have left it for longer.
This is certainly what I have heard with earlier and later 911's as well.
Old Mar 14, 2002 | 07:54 PM
Hunter's Avatar
Hunter
Post
Well, for 10-20 seconds it is okay but if it will smoke for more beware!
Old Mar 14, 2002 | 09:00 PM
Bill Verburg
Post
Often the cis cars will smoke at start up due to oil in the crankcase vent hose. This is usually the result of overfilling the oil tank.
Of course the valve guides and/or rings are often shot also.
