'74 2.4T - full or light engine rebulild?
I’m restoring a 2.4 911T as a long-term project and I haven’t decided what to do with the engine.
The engine was running but producing a lot of smoke. Of course I have no idea about the mileage of the car (though it is the matching numbers engine).
As I see it I have two options:
A) Remove everything down to the cylinders and have them reworked by a shop.
B) Rebuild the complete engine including splitting the block.
Option A is of course much, much cheaper because I can tackle most of the work myself. Splitting (or rather reassembling) the block, however, is something that I might not feel comfortable doing in my garage…
What do you guys think – is there a big chance I will regret not going the full way?
Are there ways to determining the condition of the deeper internals (crank bearings, etc.) without a full disassembly?
thanks!
Normally you'll need to break it down and measure the pistons/tolerances. You can do rings w/o splitting the case... but you can't get at the bearings. An experienced builder can make a good assessment, but anything you can't see isn't a perfect evaluation.
but now, consider that splitting the case is not much more work beyond doing a top end - it is very DIYable; OTOH you posted above that it was a block, so carefully consider your ability to do DIY
