Battery replacement
I am tired of wrestling this huge battery in and out. Is there a
good replacement. One that will fit without mods? Or Optima, but that does need some type of mod? Is is worth it and simple to install?
Where to buy?
Where to buy?
I put an Interstate model MB66 in my 88 Carrera. It is approximately 4" shorter than the one you probaly have in there now. I think the red Optima takes a special mounting bracket since there is not one on the leading edge of the battery to secure in it the car.
Good Luck.
Good Luck.
Technical Specialist
Lifetime Member
Lifetime Member
When I replaced the battery in my SC, I got one from Autozone. 7 year warranty, 2 year free replacement, has the foot on the battery so the stock clamp works just fine. Overall fit was fine, cost around $60.
Folks,
I'm also looking for a replacement battery for my stock 3.2L '86 Carrera Coupe. The current battery is an Interstate MB66-50 w/550 Cold Cranking Amps (CCA).
It was purchased in March of 1997 so I think it held up well!
The battery fits fine (really can't see how any other dimension could - longer? No Way!) and has a REALLY neat positive terminal cover (red plastic) that I DO want to have on the replacement.
My question concerns suggested Amp/Hour rating, CCA rating and (of course) finding one that is the same physical size with the correct 'feet' for mounting as well as the positive terminal cover.
Do I have any other options? The Interstate obviously held up in fine style but I don't know it's Amp/Hour rating and I'm wondering if 550 CCA is too low? I've seen 88 Amp/Hours suggested.
As an FYI, the reason for replacement is that it's starting to (slowly) not hold a charge and the car is a daily driver.
Volts from the Paris-Rhone (sp?) alternator is a solid 14.25 at all RPM's (idle and above) with a pulsing 83-91ma current draw (VDO Clock/Stock Alarm?) with all systems off, hood open and hood light disconnected - just like it sits in the garage.
A 30 minute 40A charge w/battery charger gets it back up to snuff but in three days (with daily 50 mile plus driving @ highway speeds) it's goes back to just under what it takes to turn the car over.
Thoughts?
Barry
Thoughts?
Barry
I am considering an Odyssey PC680MJ. It only weighs 15lbs and is < $100. Elephant racing sells a nice aluminum bracket to mount it with. Anyone have experience with Odyssey or the elephant mounting bracket?
1 Post
Elephant Racing caters to track guys in Calif big time.. I imagine that any product they sell is very good. Elephant's oil cooling system has a big track following. Elephant's suspension bushing up-grade is widely respected.
Check it out.
Check it out.
