Mahle 3.2 Euro Piston/Cyl Setup questions
Originally posted by Steve Weiner-Rennsport Systems
If you use a CR over 9.8:1 on these big bore engine, you MUST run twin-ignition with any pump gas.
We still haven't got an answer out of Schuey, but I think he is talking about a 95mm set from a 3.2 Carrera.
Tom
RL Technical Advisor
Hi Tom:
This applies to 95mm-98mm-100mm-102mm bore sizes.
I HOPE Schuey was talking about the 98mm slip-in high-compression version,....![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
As you wrote, the Carrera P/C's require a custom rod bushing as the piston pin sizes are different.
Let me just add a bit to this:
The need to twin-plug depends on the comp. ratio (actual), the size of the chamber (i.e. diameter), the quality of the gas, and the altitude (pressure). I suppose the very worst place to run your car would be Death Valley on a very cold day... Also consider that if you live at high altitude you may someday tour down lower...
Buildup inside the cyl. will increase the actual comp. ratio and may also serve to provide a substrate for initiation of pre-ignition.
So be sure to leave yourself some safety factor -- you won't be able to measure or calcualte all the above exactly. The rule of thumb estimates usually have a safety factor built-in.
