911 Forum 1964-1989
External Voltage Regulator Location
Old Nov 27, 2018 | 11:10 PM
Farmer's Avatar
Farmer
2nd Gear
Default External Voltage Regulator Location
I am trying to check out a charging problem on my '80 911SC. I have my voltage warning light on. I thought I would start by checking out my voltage regulator. Where is it located -- I assume it is an external VR. Thanks in advance for your help.
Old Nov 28, 2018 | 03:06 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
The VR is built into the rear of the alternator.
Old Nov 28, 2018 | 04:34 PM
Stevie 77 930's Avatar
Stevie 77 930
If you're sure you have an external regulator, it would be on the drivers side of the engine compartment next to the CDI unit
VR has the yellow tape
