as long as its out...
I have a leak coming from the crank breather on my 81 sc, I am going to drop the motor to fix this and I was wondering if there is anything else I should consider doing while the motor is sittin on the floor. I have considered doing a clutch, and I will check that but I think I will wait on buying one untill after I check the old one. I have ordered seals for the oil cooler, the thermostat, and the breather. Is there anything else I have forgotten?
Thanks,
Thanks,
Oil pressure sender seals for the unit that sits next to the internal thermostat. Common leak point.
While you have it out be sure to inspect all the vacum lines behind the fuel injection.
