911 Forum 1964-1989
PSM Failure Drive Off Assistant Failure
Old Oct 29, 2018 | 01:32 PM
Kitc2246's Avatar
Kitc2246
Default PSM Failure Drive Off Assistant Failure
Post this on the Boxster Forum. 2009 Boxster with PKD, Sport and Sport Plus. Replaced steering knuckle and got PSM Failure and Drive Off Assistant Failure afterwards. Remove disconnected and then reinstalled and reconnected the wheel speed sensor with no affect. Hooked up a Durametric and had a Steering Wheel Angle error code which was cleared. No other codes. Suspect the left front wheel sensor but would expect an ABS failure from the car. Thoughts?
Old Oct 30, 2018 | 01:50 PM
theiceman's Avatar
theiceman
Team Owner
this is an air cooled forum , try water cooled
thank s
