Ball Joint Replacement ?
If I am going to go through the process of overahailing the front brakes (disc and calipers), should I just go ahead and replace the ball joints while I am at it.
I think they are ok (just bought the car), but I will have the suspension torn apart anyway ?
Thoughts ?
Thoughts ?
JIm,
I would probably replace the bearings as well, you'll have the disc off anyway, and they are relatively inexpensive, just a thought ! And if it's a track car you may want to remove the dust shields.
Good luck !
Good luck !
