engine Serial Number
Hi Guys I have a 1969 911 Targa
The engine number has been re stamped
I am trying to work out the engine size or any other info
The serial number is 21454
The car is RHD in Australia
You will need more information than that. If it's been restamped the number it was stamped means nothing.
What's the type number?
What kind of injection does it have?
Can you access the casting numbers on the bottom side on the sides of the case, both halves?
Pictures always help things. Even if you don't know what you are looking at, we do.
Thanks for your Reply
I believe the Serial number I wrote is the type Number ? 21454 This is on the case close to the engine number on the curved surface .
It has triple Webbers
case numbers
901.101.101.2R
901.101.102.1R
Thanks Ill get some Picks up ASAP
case numbers
901.101.101.2R
901.101.102.1R
