Odometer problem
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/speed31531602377_212625ca3e130ce80059496d4726596bfdd81bfc.jpg)
Looking at these pics. can you see anything that may have stopped the odometer from working?
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/speedo11531602298_8e824e5fa8260db433734c633a2f934973352e1c.jpg)
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/speed21531602344_3cb04f91800f0c56d606d52baf86b209ca986c01.jpg)
The teeth on the first of the plastic gears in the chain are worn down by the gear from the cable. I bet if you give it a turn the teeth on the underside are worn completely through
And if I need to replace it how do I remove it?
