79' 911 SC at CaliforniaClassix....Thoughts?
I am considering purchasing this SC, and it is currently scheduled for a PPI to be done tomorrow by a local porsche mechanic in the area, RSEnterprises. I'd like to hear some opinions on it. Price seems fair, and they are willing to deal. It's had quite a bit of work done to it recently, with a full drive-train rebuild, suspension, clutch, bare metal repaint, etc. This will be my first air-cooled porsche. Recently sold my 997s. Let me know what you think,
http://www.californiaclassix.com/garage/c1151.html
Cheers,
Tom
Cheers,
Tom
Hi Tom. Welcome!
One thing I can tell you is that the engine is missing the smog pump. These were on all US 911SCs in 1978 and 1979. It should be to the left of the fan, and if you look closely you can see where they have added spacers over the long studs for the air pump bracket on the left chain housing cover.
Deleting the pump is common (mine is off), but if you live in CA, I don't think you can pass emissions testing without the pump and the associated plumbing. There should be a manifold between the heat exchangers and the engine that injects air from the smog pump into the exhaust port of each cylinder head. That also appears to be missing. They will have screwed plugs into each port where the air injectors used to be.
Mark
Mark
Cheers,
Tom
Cheers,
Tom
Sher-
