Persistent low idle after hit restart
1982 911sc
I've changed the WUR and O2 sensor but I have an odd idle issue. I've recently had the mixture set on a CO emissions machine.
The car will now idle around 950rpm, after initial warm up, but, when fully warmed up, if I turn the car off for around 20 minutes then restart the idle will drop to 3-400 rpm. It'll then stay at 3-400 rpm unless I change the idle control screw. The next morning the same scenario will occur all over again.
For example, if I drive off to a pub for lunch the idle will be fine. But when I restart the car after lunch the idle rpms will have dropped to 3-400, even if I drive for 30 minutes (with occasional stalls due to low rpms).
Any ideas?
Any ideas?
I have been thinking about the cold vs hot discrepancy in the idle speed. I am thinking about changing the vacuum hoses to eliminate any leaks. I have used Propane to check for leaks but I cannot find any using this method. While shopping for the 3.5 x 7mm tubing I have noticed the distinction between reinforced and un-reinforced hose. I wonder if I might have some un-reinforced hose somewhere on the system that might be collapsing when it becomes warm and less rigid? Would this cause this issue?
Nice idea Iceman, however, my wife is still 'adjusting' to the idea of another car and I need to keep her upbeat about it. As it is, I spend some time every trip with my head in the engine bay adjusting the idle so that the car doesn't stall and become thought of as "unreliable" for ever!
Team Owner
the real expert for these is Tony over on Pelican. he know CIS in and out . be warned, the first thing he will have you do is get gauges and tell him fuel pressures.
