Oil Cooler for 2.2S
2nd Gear
I am in the process of switching the 2.2T motor from my 70' 911 to a 2.2S. I now need to incorporate an oil cooler and lines to the front of the car. Of coarse I am trying to do this as cheap as possible and I have heard a cooler out of a RX-7 might work. The question is, does this work and if so, what generation Mazda's will work? Thanks for any help or advise on the topic,
Grover
Grover
BAT in Sarasota, FL sells an inexpensive fender radiator system that I have heard works well. By the way, the Trombone Cooler is found in the 1973 RS, ir did the job for 210 HO. Also note that brass lines to and from the oil cooler from the thermostat provide additional cooling. Get these if you can. Good luck with the project.
