starter replacement
Hi Antonie..basically jack up the car and use jack stands so you are safe.
Or if you can use a lift.For starter work, disconnect the battery.Then for he upper allen nut 10mm use the tool from your tool kit ,if you have one.Reach around the trany with your right hand.Only after you remove the bottom allen but or sometimes just 15mm wrench nut,it dependent what people used on there.
let us know if this help you..
Ivan
Ivan
