1980 911 SC heater hose replacement
Hi,
I have attached a couple photos. Which hose do I need to order? I have looked on the usual sites but its a bit confusing.
I need the hose(paper/aluminum I think) that goes from the right underside across the fan to top left side of the engine. Mine is crumbling. It appears there are 2 and use a reducer just to the right of the fan,. Could someone provide a link. Thanks.
I have searched on here but no luck. What is the trick to searching this site ?
trying to find similar to this style on the left side
Randy,
When I want to find something here or on Pelican, I preface the Google search with Rennlist: or Pelican:
The paper/aluminum hose is 911.211.522.01. Should be 60mm in diameter. That more flexible hose you have on the left side looks more like the hose that connects the heat exchangers to the flapper boxes to get heat to the cabin. I believe that one is 2.5 inches.
In my car I have the 60mm aluminum/paper hose on both the left and right side feeding the engine compartment blower.
Mark
Mark
Thanks Mark, I appreciate your input, huge help.
Randy,
Mark
Mark
