718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Track tyre wear - doctor’s advice needed
Old 09-23-2024, 01:35 PM
Laur3ns
Cruisin'
Laur3ns's Avatar
Default Track tyre wear - doctor’s advice needed
Hi all,
My car:
718 GT4 MR
Camber -3f / -2.5r
Toe -1mm f / +2 mm r (both per wheel)
OEM height, rake and sways.
Cup 2R front left looks like this after two hours of a CW track (Zandvoort) running 1:53's.
Not so much worried by the wear itself but more by the pattern. I seem to use only a small part of the tyre.
Is this the part with the softer compound and hence wears faster? Different pressure, camber, toe needed? Driving style*?
Hot pressure around 2.1bar/30.5psi front and similar or slightly higher rear.
*) Onboard of that session:
Old 09-23-2024, 05:30 PM
lovetoturn
lovetoturn's Avatar
Received 1,164 Likes on 569 Posts
More camber -3.5/3.0, add a few more clicks to the coilovers, and stiffen the bars one or two holes per axle. That, and the 2Rs are very soft and don't last that long. That is what happens to Manthey tires on the ring too.
Nice lap and splitting those two at the end. Thumbs on that one.
Laur3ns (09-23-2024)
Old 09-23-2024, 05:56 PM
beez
beez's Avatar
Agree - maybe a bit higher hot pressure to 32 psi. I've used only one set of Cup2r with a 991.1 GT3. Got 5 30 minute sessions out of them on a 3 mile track... on the third lap of second session of day two, they literally fell off a cliff. Two laps felt great, halfway through the third lap, ice skating.
The following 2 users liked this post by beez:
Laur3ns (09-23-2024), lovetoturn (09-23-2024)
Quick Reply: Track tyre wear - doctor’s advice needed
