SRS tire pressure
I agree, the SRS door card some seem a little incongruent with other cars in the range with the rears being as high as they are but it's a pressure that's derived based off the cars weight and suspension springs and dampers that should give the best overall tyre life.
I don't know what Manthey recommend for other tracks but ideal pressures are pretty universal regardless of operating conditions. For fast lap times, as low as you can get away with is generally the rule of thumb.
All of my personal best lap times have been set with pressures at or about 0.1 Bar below door card pressures (2.0 / 2.3BAR on my car). NEVER above them. Running as low as Manthey recommends might give better lap times but it eats sidewalls and throws constant TMPS warnings.
According to Porsche manual and Service Manager it recommends to view the second screen that shows all four tires - + values . If values are 0 then that the correct pressure , If the values are a - or + then air needs to be added or removed . GO FIQUIRE
Where do you access this menu??
The tire pressures indicated on the door sticker are often incorrect.
The Owner’s Manual states the correct cold tire inflation pressures for normal driving.
They are:
29 psi Front
33 psi Rear
(See attached.)
“Cold” means ambient driving temperature before driving begins when the car has been at rest for several hours. If there is a difference in air temperature between where the car is stored overnight and the outdoor ambient temperature where the car will be driven, then the setting of the “cold” tire pressures needs to fluctuate accordingly before drive-off.
So if your car is in a heated garage overnight at 75 degrees but it’s only 50 degrees outside, the cold tire inflation pressure would need to increased to compensate for the loss of pressure due to colder air. In this case you’d increase all values by about 3-4 psi. I imagine there’s a chart for this.
Same applies in warm climates where the car might be stored in an air conditioned garage.
I have never heard of lowering tire pressures if driving hard or fast. On the contrary, German manufacturers expect their cars to be driven at autobahn speeds and therefore they often list tire pressures suited for high speed driving, which usually consist of at least 4psi added to the stated inflation values for normal driving. Higher consistent speeds such as 100+ or 130+ require more inflation pressure. While Porsche has not done this (lately) in their Owner’s Manuals, I can say for sure that Owner’s Manual after Owner’s Manual lists (higher) inflation pressures specifically for high-speed driving.
I am not speaking about track driving here. Inflation pressures on track, as with just about every other performance setting on track, fall into the category of “deep dive pick your preference track setting.” Considerations of art, feel, rule of thumb, and personal preference apply when the discussion is about settings for track driving.
For street driving, this matter is a matter of fact rather than a matter of opinion, as long as we agree that we should do what the car manufacturer says and we correctly apply the mathematics involved.
They are:
29 psi Front
33 psi Rear
(See attached.)
They are:
29 psi Front
33 psi Rear
(See attached.)
They are:
29 psi Front
33 psi Rear
(See attached.)
Fact is tires need more pressure under high stress conditions. Like deflating a football, there might be a handling advantage but there will be a structural and wear-and-tear disadvantage.
