Are others experiencing power loss under track conditions in GT4RS?
Right now, I am really limited as to the data I can collect as the local dealer recommended disconnecting the Solo 2 data logger from the car. I can reconnect the data logger to the car after the problem re-occurs with no data logger. I could then collect fuel pressure info by requesting live data (via my Foxwell scanner) and recording the results (via the Solo 2).
Great input. Thanks.
If youre stock and tracking alot, i bet your opf matrix is jammed up. Just knock that stuffing out i bet u never have that problem again
sounds like your car is choking
What tires are on the car, and are they different from the OEM sizes? Super sticky tires (like Hoosiers) can exceed the g-forces the traction control electronics are expecting to see, and activate the traction control. Also tire sizes that are more than 3% different in diameter to OEM sizes can do strange things to the ABS system that also sends information to the TC system.
Particulate filter located in your OAP (over axle pipe). It's there for ROW cars but not used in the US. Guys have chiseled out the filler inside them. Wild guess but my first thought is debris in your fuel tank that's moving around under extreme G forces causing momentary fuel issues?
Haven't experienced and not much more to add, other than I've never experienced temps above 220. Granted elevation is only 900-1k feet and temps have only been as high as mid 80s. But about 20 degrees cooler than my other car on track
No such experience since owning the car since sept -22.
What happens if you don’t come off the accelerator and just stay floored?
