718 GTS 4.0 PSE not engaging in Sport/Sport +
'21 718 GTS 4.0
Symptom: PSE not automatically activating (red light on PSE button and valves open) when Sport or Sport + is selected using the drive mode dial on steering wheel
Note: drive mode dial functions properly in all other regards....ex. damper selected in Sport +. Also PSE functions properly when button is selected...ex. light red and valves open.
Additional Note: Setting PSE (box checked) in the Individual settings via steering wheel/gauge cluster...also DOES NOT set PSE to active when I then select Individual on the steering wheel dial.
As anyone else experienced this? I've had several GTS trim p-cars and all behave the same with regard to PSE and selection of Sport/Sport +. Heck, I had a '21 Base Cayman that had Sport Chrono, PSE, etc. and it activated PSE when Sport or Sport + was selected.
For some reason this new-to-me 718 GTS forces me to manually select PSE no matter what drive mode I've selected. I've poured through the manual and all the dash and gauge menus to no avail...
(?) Is there a relay between the steering wheel dial and PSE that might be bad?
(?) Is there possibly some programming change Porsche did to this model?
Any help would be appreciated.
Previous owner may have installed a memory module for the center console buttons like the one from t-design9? Or I suppose the car could have been reprogrammed?
Sounds like something the previous owner did. So the red light doesn't automatically turn on in Sport/Sport +?
If so, then it definitely sounds like they remapped it. Which is actually a good thing because by default, it's impossible to have the valves open before ~4k RPM, no matter what settings you have selected (the light lies to you). Aftermarket solutions actually open/close the valves as expected.
sonicworld (12-30-2023)
FazedChicken (12-30-2023)
'21 718 GTS 4.0
The car is booked in to have a module replace this Wednesday. I really hope it works as the car has been in their workshop multiple times.
WillyDaP (12-30-2023)
@kkozar , with your car being a 2021--I'll presume it is still under original factory warranty. If that is the case, what about just taking it to your dealer as a 'fix under warranty' issue and let them resolve?
For anyone with a 718 GTS or so equipped with PSE....note the PSE is supposed to engage with selection of the Sport/Sport +. If it doesn't you might have a bad AC Unit (main control for the center cluster). This might be a known issue by Porsche as they have a new AC unit out....prior one has been superseded. So have your local dealership take a look. BUT...be careful, if the replacement AC unit makes everything worse...they might have installed the wrong (superseded) AC Unit...trust me...I know!
slilley (04-04-2024)
