GTS 4.0 PCCB rim - brake caliper clearance
Searched the forum, but couldn't immediately find an answer for the 718.
Does anybody know how much clearance there is between the brake caliper and the rim with the carbon ceramic brakes?
There seem to be issues with stones getting catched between the caliper and the rim, which results in scratches on the caliper and the rim, especially with 911's.
I also wonder how easy it is to clean the inside of the rims with PCCB's without moving the car.
I'm in a wheelchair, and moving the car everytime to clean a part of the rim is annoying, since I have to get out of my wheelchair and sit on the ground to clean the wheels.
This is not a problem with my current 981 GTS and steel brakes, I can easily clean the complete inside of the rim without moving the car.
The only reason I would buy PCCB's is brake dust, which is a PITA with the steel brakes on my current car.
But rims also get dirty from the road, so cleaning remains necessary.
There are several advantages to PCCB, IMO. You already mentioned the brake dust issue. You can basically wipe off the miniscule amount of dust with a dry microfiber towel. Unless you are regularly tracking, you will never have to replace the discs, and possibly not even the pads, for the life of the car. Finally, the significantly reduced unsprung weight helps a lot with ride quality. I have ceramics on my Spyder and my daily driver Audi RS5, and love the initial bite. Gives you a lot of confidence.
Did you receive a Porsche Build Code with them included? Please share if that’s the case.
Or is it a case of “will be” meaning some future availability? If so what build week do they become available?
Congrats on the allocation!
I’m sure more would want to understand this availability.
Internation Configurator
Looks like I was seeing this on the international configurator. Not sure this represents something you can actually buy. I don't see PCCB available on any region specific configurators.
I ordered my car in Germany. PRDE6Y26
Site is in German of course.
The dealer configurator showed it as available, but I don't rememer the exact date. Production is planned March 2024, and dealer confirmed PCCB would be available by then.
The 718 (non-GT) PCCB front calipers are identical to the GTS 4.0 iron caliper aside from color. The rear are also identical but have ~10mm taller mounting posts to accommodate the 350mm discs.
The photo in the configurator is incorrect in showing what appears to be 410/390mm rather than 350/350mm per the information provided. This happens often with the configurator.
Since the larger GT4 size calipers and discs aren’t directly compatible with the standard 718 knuckles, 350mm front and rear is correct.
Wheel to caliper clearance therefore won’t be an issue.
HTH
The configurator says, “350 mm vorn und hinten, 6-Kolben-Bremssättel an der Vorderachse und 4-Kolben-Bremssättel an der Hinterachse,” so you’re getting the same PCCB calipers and discs for all of the 718 non-GT cars.
HTH
HTH
GTS 4.0 calipers are on 142mm bolt spacing and have 30/32/34mm stainless steel pistons. They can accept a 350mm rotor but can't be spaced out to 380mm due to the angle of how the bolt holes are drilled into the casting. 991.1 and 991.2 Turbo calipers share the same body but have taller posts to accept 380mm rotors natively. They can accept up to a 34mm wide disc.
GT4 calipers are on 225mm bolt spacing and have 30/30/30mm stainless pistons with ceramic caps to minimize heat transfer into the fluid by way of the pads. They can accept between 380 and 410mm rotors depending on spacing (which varies by part number). They can accept up to a 36mm wide disc depending on the length of the pad retention bolts (which also varies by part number).
GTS 4.0 caliper left (9P1-615-123-T) vs GT4 caliper right (991-351-428-86):
037 (11-22-2023)
josbmw (11-23-2023)
Final configuration went in yesterday.
I ended up with this (I ordered the car in Germany, so no English) https://configurator.porsche.com/porsche-code/PRH4EDN7
