Creating a thread to reach out to those who have had their GT4RS PPF'd. I haven't found any discussions or detailed images of tricky areas such as the lower front fenders. I just got the car back after two weeks from a full PPF, but have scheduled a follow-up to address the issues. If any of you could provide feedback on expected PPF quality, or share photos of the problem areas I've highlighted that would be greatly appreciated. I'll add specific questions under each of the photos.
Front fender louver vents
How close to the edge can the film get? Is there anyway to tuck the ppf under the vent? The gas cap also isn't tucked, doesn't seem right.
Lower front fenders + Side skirts
Can the film be tucked, and potentially avoid the seam at the hard edge at the bottom of the fender? Worried in a year or so the exposed paint will be destroyed from rocks.
A-pillars
Can these be tucked to avoid taking rocks head on? These are already starting to peel and collect dirt.
Side mirrors
Hard to see, but only the top portion is covered with film. Can it be covered with a single sheet of film, or where should I expect a seam?
That definitely looks like pre-cut and NOT custom. if they extended the edges, the PPF edges should not be visible; they should be tucked under the panel. I'm in the Los Angeles area. I paid $8k for full custom XPEL PPF, including headlights, and XPEL ceramic coat including wheels and brake calipers. I have some seams showing but all are acceptable (e.g. curvature of side mirrors and wing).
LIf they said they’d tuck it, they definitely didn’t come close… although in those high to wear areas if you’re expecting it to only last a year. The edges will be the least of your problems. I’ve never had a ppf edge show dirt even 6 years after the fact.
oh sorry, I was referring to the exposed paint at the edges not the actual ppf. I’m assuming the ppf should last years.
Your installer used template pre-cut PPF for installation. You can expect to see gaps like this when using pre-cut film.
With that being said, the gaps do look larger than what I've experienced in a pre-cut installation. The Xpel HQ facility is in my town and they will use pre-cut, but the gaps are much smaller. Guess it comes down to the software, template, and equipment.
If the installer quoted you a custom tuck, no seam job -- then yes this is not it. What did the install contract specify?
Personally. I not a fan of the no seam custom job. It requires some disassembly of the car and in some areas they'll cut the PPF on the car.
Nothing unique to a 4RS...use the advanced search and put PPF in the search title -- hundreds of threads on this.
Precut usuals. Could have been slightly better
Custom cut has its own issues if you want someone to take apart your brand new car
both have pros and cons. Protection will be fine though will just the little exposed area.
"All edges of film tucked and rolled".
A lot of discussion happened over the phone and in-person as well. I didn't expect a full custom seamless result, but discussed that the plotter allows extending to fully wrap and trim excess for clean edges. They are being super helpful with bringing the car back to fix, but wanted to reach out here to get a better idea of any info I can provide and check my expectations aren't too high.
Thanks Kirby, I've seen these! Love your cars. They did an amazing job and if I still lived in the Bay Area I'd be giving them a visit. I'm in North Texas and did not find any custom installers, all used plotters and extended the edges to wrap and trim excess. I didn't have expectations for a seamless custom install, but did expect the edges to be tucked/wrapped.
I’d be a little hesitant to ask the installer to roll and tuck the film without checking their work on other cars first. As a matter of fact, I’d probably go around to different installers to check their work to compare. The last thing you want is somebody, without experience, going near your car with a blade.
Something I’ve learned after all these years of modding and that is nothing ever comes out perfect. And sometimes, when you try to fix it, it actually ends up being worse. $8k for precut is a bit much unless they did other things like window tint. Instead of having them try and fix it, I might consider getting some money back instead and keeping what they did. I’ve seen a lot worse.
