Oil use GT4RS
#31
Peter
#34
My oil is showing half way on the electronic dip stick. About 680mi. I didn’t check the level before. I did pick up the C40 oil at the dealer for top off.
#36
New GT4 RS full quart of oil required with less than 400 miles
Left the house this morning with about 300 miles on my GT4 RS. At roughly 370 miles I got a low oil level warning. Had to go about another 30 miles before I was able to stop and get some synthetic oil. Added a full quart and the electronic oil gauge now reads full. I'm. a bit blown away that a brand new Porsche would need a full quart of oil at only 300 - 400 miles. Seems crazy. I've noted that a number of people seem to feel that the factory didn't fully fill the car with oil when it left the factory but I would have thought that my dealer would have checked this prior to delivery. Out of curiosity, would it be considered normal for one of these engines to go through a full quart of oil when car has under 500 miles?
#37
Oil usage should decrease after break-in, but these motors still use a little.
#38
Juggy (06-18-2023)
#39
Mine arrived from factory/ dealer with only 30% on electronic gauge (bottom right stalk, push away, scroll to oil level and get a reading) . I am now at 20% after 600kms. Waiting for oil to come from the UK as cannot get the C40 oil in 0w-40 in Australia except in 5 litre containers as a special order.
Hope your top up using synthetic oil was a C40 oil...otherwise can play havoc with petrol particulate filters!
Top up from '0' to 100% is 0.8 of a litre/quart of oil, according to manual, and as GT4RS is best at 75% then half a litre/quart is about correct amount.
#40
I’m currently at 1100 miles and my oil reading is in the middle.
#41
Just be sure if and when the low oil warning comes on not to add a full quart. 26 or 27 oz. (0.8 qt) would be the max to add or you will be overfilled and that is not good. As @johnrichard points out 1/2 to 3/4 between min. and max. is just about ideal. Adding 0.8 qt when the warning comes on, as per the OM, will show it at the max. mark. I went to Watkins Glen this weekend and put about 600 miles on the 4RS (now about 1600 total miles) and it still reads at max. Hope this helps.
#44
At 14 mi my 4 RS was reading a 3/4 full oil level. At 2000 mi, just before an oil change
at Manthey, my oil level reading was 2/4 full. Manthey filled to 3/4, as per recommendation. Now at 4050 mi my oil level is 2/4. Each quarter unit on display should correspond to ~200 mL.
So, I can happily report a (negligible) ~0.2 L / 2000 mi oil burn. She's healthy and she rips
YOBMV (OB: oil burn)
#45
Not an oil use post, but still kinda on topic. Got my 1st oil change yesterday at Porsche dealer...$496.00 WTF!!!
Not my 1st Pcar, it's the 4th one, so used to the maintenance costs, but this is F'ing outrageous!
It is my 1st RS, so if this is normal for an RS just say so and I'll stop the rant.
If i got ripped off, gonna out the dealer on Google review and Porsche satisfaction survey.
