Duck Bill wing
^^^^^. The idea is to make a Cayman GT4 (GTS) Touring replica. I wanted a GT4 Touring but Porsche had different ideas. So I want to add a GT4 side scoops and rear ducktail spoiler and GT4 front bumper with a Spyder splitter. The Spyder splitter and rear spoiler work well together without a wing, so that is the direction I am leaning towards.
Here's a full aftermarket GT4 kit https://rexsupersport.com/carbon-par...t-pp-material/
I also want to make a GT4 touring out of my upcoming GTS 4.0. I like the cleaner more classy look.
Really wish someone made one of these unpainted so you're not paying extra $$$ for no reason. I want it to look as OEM as possible.
Has anyone tried buying all the underbody GT4 plastic pieces and putting them on a GTS? I want the stealth look so I was considering doing all underbody stuff only (including rear diffuser).
I was quite pleasantly surprised how much the Spyder Spoiler on the Boxster 25 added to the aggressive of the look of the Boxster 25.
I don't think we are talking about high levels of downforce for the Boxster GTS 4.0, Cayman GTS 4.0, or even the Spyder. The Aero is there to make sure the car doesn't have lift at high speed, at least keeping in neutral.
That said, I think for my "Project GT4 Touring" I am planning to do later this year, as I mentioned I probably will do a Ducktail Spoiler of some sort, paired with a GT4 front fascia of some sort, and maybe also do the GT4/Spyder rear diffuser, and look at the underbody aero as well.
Theoretically that would have a very similar Aero balance to the Spyder, especially if I did the OEM GT4 Front Fascia but with the Spyder Front Lip.
shiftgear (07-02-2023)
Yes, I have thought of that. I put the TWL Carbon Ducktail Spoiler on the the Albert Blue Cayman GTS 4.0, and that was fine, I experienced that up to speeds of 130 mph+, and didn't notice any change in stability. I also did the Spyder Spoiler on my Boxster 25. I did 49 Track Sessions with that last year and routinely was at speeds of 125 mph+ in the track sessions. I didn't notice any change in stability there either. See here, this pic is the Boxster 25 with the Spyder Wing, raised at speed. Speed on this straight at this point is 120-125 mph, coming into a kink over a curb that is pretty hairy. I didn't take that turn and curb nearly as quickly in the Boxster 25 as I did later in the GT4 and more so now with the Cayman R Race Car, but that has more to do with the suspension, alignment and tires. In this pic I am pretty sure I am into braking coming into the kink/turn.
Visually I have always found that you need to do both front and back to balance the look visually. For this reason I haven't added a larger spoiler.
One thing that I would like to change is the rear GTS diffuser. Looks cheap and not aggressive enough.
For the pics you posted, what wheels are those and what size? They look great on the car!
They are HRE P101 SC Wheels in Satin Black. Specs - Fronts: 19x9 ET50, Rears: 19 x 10.5 ET44, with 19” Michelin Pilot Sport 4S Tires, 255/35R19 Fronts, 285/35R19 Rears. With the GT4 I had 255 Fronts and 295 Rears, Cup 2's.
I use the Apex Racing Fitment guide for wheel and tire fitment, for 19" wheels that 255/285 is their recommendation ("staff pick") for both the GTS's and GT4/Spyder. I would have tried 265/305 on the GT4, but you need camber plates to do 365's on the front, and I didn't get around to doing that before the end of the track season.
Here is a closer up shot of them, from yesterday after getting cleaned up to go on the Spyder:
Here they are on the GT4:
FazedChicken (07-04-2023)
Hello Pete et al,
What are your thoughts about installing the Frog Venom rear spoiler on the CGTS 4.0 without doing anything to the front splitter? It sounds like you would not have a problem doing that and potentially being a little out of balance, correct?
I assume the Frog Venom rear spoiler is similar to the Spyder's rear spoiler. Does the Spyder have a significantly upgraded front splitter/spoiler as compared to the CGTS4.0?
Thanks.
Thanks.
See that Spyder front bumper is very similar to GT4 (with slight differences). I guess on paper that front end balances better with the rear spoiler on the Spyder. I would say what I am wanting to do with the FV rear spoiler is very similar to what you did with the Boxter 25. Thanks.
Basic Sponsor
I wouldn’t worry about an imbalance as such, you’re going to only notice it on Track (if at all) and at that point could reset the imbalance with some more front aero / suspension tweaks.
My 718 GT4 Euro Delivery Thread
Contact me for the best pricing on Quality Parts
- alex@lepetitgarage.us
LePetitGarage.us // @_lepetitgarage on Instagram
Digger38 (03-10-2024)
I am not sure that the aero works at speeds under 80 mph and most likely does not come into effect until you are tracking the car. I have had it up over 100 a couple of times and have not noticed anything, good (downforce) or bad (upset handling). I am going to Sebring this weekend and will see if I can get some speed on track and see how she handles.
Your Beauty has a GT4 front also! This should most definitely provide some balance. I think most are saying, even without anything added to the front, adding the enhanced rear spoiler like you have done probably won't make any difference until you are really getting to some track speeds (if even then). Your thoughts on this? Thanks.
