Changing tire sizes
Changing tire sizes
Hi all!
changing tires from 2022 Spyder Michelin cup 2 to Michelin pilot sport 4S
Would there be a reason to go from 295s in rear to 305s? Looks? Any issues?
thanks As always!
Rob
thanks As always!
Rob
Understeer would be reinforced by going to a larger rear tire. Depending on how much your car has been lowered and/or camber they may not fit.
corrected from oversteer to understeer and provided additional details after rereading the question
As was mentioned it depends... With an all-stock suspension with stock wheels and offsets you should be able to go to 305's, a few Spyder's owners have done this.
Remember it really depends on the wheel and tire combination, change the brand of either and everything changes...
So below with the OEM wheels and 295 (section width) Dunlop Race 2's as compared to 305 (section width) Bridgestone RE980AS... I would say that the 295 looks as big or bigger that the 305
Dunlop Maxx Race 2 295/30ZR20
Bridgestone RE980AS 305/30ZR20
If the clearance is tight, you could have rubbing. I studied a number of pictures before moving up to the 305 in the RE980AS, I knew that its profile was actually less than the 295 Race 2 and therefore safe for clearance. In this case my goal was to get close to the OEM supplied Race 2 but not to exceed it.
