Gt4 charging issue
Hi guys,I have a 2020 gt4 which is great. I brought the car to get a lightweight flywheel installed. Since then I got problems with the battery charging. Sometimes the voltage is around 14.5v and it's normal. The problem is that for a big part of the time,it goes around 13.1v and I had it once going 11.9v. I cannot find the issue. I replaced the ground wire from engine to drive train without success.
Do you guys have an idea or somebody had similar problem?
Isn't it under warranty still? Troubleshooting electrical/wiring is one of those things that is next to impossible to do over the internet.
In theory could be a bad battery too with the age since the car is about 4 years old it is technically long enough to have a battery issue especially if that car didn't sit on a trickle charger over 3-4 winters. I've seen a bad cell in a battery cause some really wonky issues. It would be very odd to have an alternator problem, especially on a car so new.
The following 2 users liked this post by Zhao:
Larry Cable (04-15-2023),
Rupert16 (04-16-2023)
Thanks for the reply guys. I know electrical problems aren't easy to diagnose I wrote because I though that somebody could have gotten the same issues. The Car has the approved however the problem is that they don't seem to know what they are doing because they keep telling me the coding is the problem 😐.
I bought and replaced the ground wire to be absolutely because I though they might have been pulled during the flywheel change. The output is 13.1to 13,7.
I have a liteblox coming this week so we will see if it's a matter of a battery.
It was a June build but we didn’t receive it until mid September.
I followed it from place to place in Germany, including being caught up in that Labour dispute at the shipping port.
I also believe, once our dealership received our vehicle and being late, they spent little time checking all possibilities of a weak battery etc.
I can say this, because my wife and I only drove it a few times before placing her into winter storage.
I was surprised to find after less than 3 weeks, in my heated garage the battery was way below 12 Volts.
I had purchased the Porsche battery tender, so she has been on the charger most of the time.
Yesterday was it’s first time out this Spring, so now she’s insured again I’ll be making an appointment with my dealership.
Hopefully they might replace the battery?🤔
Yes I agree with this person, my 2022 build Spyder has an issue with it’s battery I believe.
Just checking that you have connected the charger directly to the battery poles. This is because the Internal Electric sockets disconnect from the electrical systems after a short period of time post locking/closing the car. I think this was to stop people draining their car accidentally by leaving a GPS/camera connected. So connect battery direct to poles in the frunk and see if the charger can sort the problem !
If you connect an accessory such as a camera or radar detector that is drawing/draining the battery it will shut down. IIRC after about 30 minutes.
If you’ve experienced otherwise post up the charger and conditions that disconnected in a 718. There are some problem chargers out there.
they means the dealership which replaced the flywheel. I started having problems after they replaced it. I have This issues when the engine is on of course. It seems the alternator isn't charging the battery with the proper voltage. It sits around 13, but sometimes it goes at 14.5 which is normale.
The dealership,keeps telling me it's due to the battery coding and that the car sometimes could loose it. Of course I don't believe them.
This has never happened to me while using a CTEK charger and the smoking package receptacle. Over 15000 miles and 2.5 years in my 718.
I will however, go on to say that I connect up the maintainer within 5 minutes of turning the vehicle off and I leave the garage parked vehicle unlocked. This process survives for weeks and even months as long there is no AC power interruption.
Mine gauge indicates charges voltages that vary, but generally in the mid 14V range and quite often in the 15V range.
This is the charger I use.
CTEK MXS 5.0
