718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
GT4: Anyone with coilovers?
Old 04-14-2023, 04:22 PM
Montaver
Montaver's Avatar
Originally Posted by 964C4
I feel shocks are not stiff enough, so I wonder:
- enough to change only the springs and keep OEM shocks with OEM height?
- better upgrade to MANTHEY coilovers and lower the height of the car as per MANTHEY's specs
My goal is to improve my lap time by around 1.5-2.0 seconds per lap in my local track (other GT4's are with same timing as I am now and with simmilar upgrade as my car)
The stock suspension is very good, it shouldn't hold you back from going fast. It is on the softer side though, so rewards being smooth. I tracked my 981 GT4 on stock suspension for years and got good times. You would see 1.5-2.0 seconds on a big track by changing a 19inch setup with sticky 265 front tires assuming you have not done so already.
Given you are in Europe I would consider Bilstein Clubsports, Ohlins TTX, or the Manthey kit. The Manthey kit is stiffer than stock by about 50% at the front I believe, but that's quite low compared to custom kits folks in the US are running. I believe Ohlins R&T is an 70M/mm and 90N/mm, Bilstein is similar around 80/100. Personally I would go TTX or Bilstein over the Manthey but there is certainly some paddock bling factor to having the Manthey.
I have MCS 2WR going onto my car, hopefully next week. I'll be able to set times at WGI and compare to my stock 981 next weekend, if it doesn't go on in time I'll be running stock 718 suspension which is an even more direct comparison.
The following 3 users liked this post by Montaver:
964C4 (04-16-2023), alwaysdriving (09-11-2023), l30thelion (06-08-2024)
Old 04-14-2023, 04:42 PM
TRZ06
TRZ06's Avatar
Received 1,645 Likes on 934 Posts
Very cool. Let me know what you think of them or if you have any set-up questions on them. I have played with a lot of settings over the last year and don't mind sharing what I have learned.
Montaver (04-14-2023)
Old 04-14-2023, 06:50 PM
Snowy999
Snowy999's Avatar
I have Manthey 3 way coilovers. They are expensive £7k but i am pleased with them. They have a higher front spring rate (as already recommended by others here).
The following 2 users liked this post by Snowy999:
964C4 (04-16-2023), TDT (10-05-2023)
Old 04-15-2023, 01:54 AM
edub
edub's Avatar
Originally Posted by donR
The tractive dampers are electronic and by design they make a constant faint high pitched noise/squeal which normally isn't audible in the cabin due to fire wall, insulation, etc. However, in the Cayman the rear dampers are very close behind so I can hear the damper squeal, particularly when parked. Un-plugging the damper/PASM cable eliminates the noise, although this could be unique to my damper set, as I haven't been able to confirm otherwise with other Cayman/Tractive owners. Interestingly, if I put in the OEM PASM controller the noise also goes away but then of course the dampers do not work properly. So could be just some unique issue relating to my setup or some module in the damper that needs replacing. I'm sure if I was in the US or Netherlands it could be sorted.
I have a cayman and the Tractive 'Touring' dampers (not to be confused with the 'Road and Track' or 'Motorsport' models)
I don't hear noises when they are on. They will work with the OEM PASM controller, in fact all the Tractive struts use the same DDA valve which operates on the same settings as the OEM PASM controller uses (the PASM defaults to 1400mA and 800mA in Sport mode). Using a DSC, you can send a larger range of current to the strut valve, between 2000mA and 600mA. Less than 600mA the valve is already closed so not much point in that.
I would write to Tractive to ask if there is an issue, hearing a noise. What suspension controller are you using when there is a noise?
Old 04-15-2023, 02:04 AM
dnimi123
dnimi123's Avatar
Received 1,116 Likes on 675 Posts
MCS 2WR HERE AT 90/110 F/R SPRING RATES. Love them and makes huge difference. More compliant around town and more stable at speed - win/win. Highly recommend.
The following 2 users liked this post by dnimi123:
Old 04-15-2023, 08:35 PM
donR
donR's Avatar
Thanks, good to hear from another tractive owner. I have the Road/Track dampers which run anywhere from 1700mA down to 300mA full firm. I have contacted the local supplier who have spoken to tractive but no workable solution as yet. It is a 2 hour round trip and $$s every time I am there so I haven't been too motivated to resolve the squeal as my car is mainly for track use. The noise does go away with the OEM PASM controller, but not a second DSC controler so definitely something to do with the dampers.
Old 04-15-2023, 08:50 PM
DR.S
DR.S's Avatar
My only gripe with the tractive dampers is they have a very faint high pitched electronic squeal which is audible in the cabin from the rear dampers at low speeds on smooth roads but this may be unique to my install.
Are you sure, it's from the dampers coming and not the DSC?
If you hear it while driving and it disappears few seconds after you stopped, it's not the damper.
Old 04-15-2023, 09:09 PM
edub
edub's Avatar
I would be surprised if the R&T dampers used a different range than 2000mA - 600mA. As far as I know, they all advertise using the same valve, so it reasons the same settings.
Don't make more trips, this should be email and verifiable with phone/video in my opinon. As you've a DSC, you can easily run the current to whatever you want and test the valve. You can also test individual shocks yourself, and see if its just one strut, the DSC or something else making the noise.
I'd be happy to help walk through some things to troubleshoot but I'm nobody special, just an owner who is curious about things.
I'll also write Tractive and ask about support in Australia.
Are you confidant that the DSC is using a profile for your dampers/car?
Old 04-15-2023, 10:04 PM
donR
donR's Avatar
Thanks for your help, I do feel a bit alone in this given I haven't heard anyone else with this high pitched squeal noise.
In any case let me PM you as I didn't mean to detract from the OPs post which was coil-over options.
If anyone is interested here is the US supplier for Tractive. Mine came with Eibach springs given they were sourced out of Europe, but nothing wrong with the US Swift springs:
https://www.tpcracing.com/product/po...-rt-coilovers/
They also have various pre-developed DSC maps/calibration files for various Porsche models to download:
https://www.dscsport.com/calibration-files/
Old 04-16-2023, 03:25 PM
jwr9152
jwr9152's Avatar
I run the stock struts with Swift 80/100 springs and a DSC. I have a firm program and a soft program and it's track dependent on which is faster.
Haven't noticed much if any difference on the street, as far as, harshness of the ride.
I set respectable lap times wherever I go with that set up. Have lap SCCA TT lap records at NCM and Road Atlanta. Would have a NASA lap record at Nola, but didn't run in my class for that event.
You can probably pick up some time with coilovers if the stock suspension is causing you to lose traction.
Like Montaver said the easiest way to pick up 1.5-2.0 seconds is switch to some sticky tires on 19" wheels with 265 fronts. Falkens RT660, Yokohama A052, Goodyear sc3r, or the new Bridgestone RE71RS when they come out with a 305 are all faster then cup 2s.
The following 2 users liked this post by jwr9152:
964C4 (04-16-2023), Larry Cable (09-10-2023)
Old 04-16-2023, 03:44 PM
964C4
964C4's Avatar
Thanks for all the replies, appreciate it!
Will get MANTHEY coilovers in June
The following 2 users liked this post by 964C4:
Larry Cable (04-16-2023), Montaver (04-18-2023)
Old 04-18-2023, 01:37 AM
paffinity
paffinity's Avatar
What is your experience level? You could get that with tires alone if you're on stock Cup2.
I've made the mistake of throwing money at cars and making them unusable (or very uncomfortable at least) on the street.
Old 09-10-2023, 06:31 PM
Specracer23
Specracer23's Avatar
The replacement DSC dynamic suspension module upgrade was great Read about it https://www.dscsport.com/product/dsc...v3-controller/
Old 09-10-2023, 08:33 PM
Drifting's Avatar
Received 1,316 Likes on 690 Posts
How would coilovers compare to the GT4RS stock suspension, which is quite stiff?
Would it make more sense for someone who owns a PDK GT4 to consider a GT4RS?
Old 09-10-2023, 09:28 PM
Larry Cable
Larry Cable's Avatar
Received 3,627 Likes on 2,355 Posts
being pedantic (ok ****), AFIAK PASM are considered coilovers, so really one should ask about "aftermarket" coilovers... jus' say'in!
before I'd invest in an aftermarket 2/3/4 way adjustable coilover I would:
- get a proper track alignment, and replace the rear toe link with either TPC or Tarrett
- replace the OEM PASM controller with DSC
- consider add different springs
once you go down the aftermarket setup you really need to know what you are doing w.r.t suspension setup and adjustment..,
The following 3 users liked this post by Larry Cable:
alwaysdriving (09-11-2023), dnimi123 (09-11-2023), MechEngr1287 (09-10-2023)
Quick Reply: GT4: Anyone with coilovers?
