oil change at 2200 miles. Yeah or nay
FWIW I followed the AP break-in method and immediately did a 2 day HPDE at New Jersey Motorsports Park. I decided to have the oil changed at 1,275 miles and couldn't find any Mobil 1 EXP X3 0W40, so I went with the Audi 0W40 that meets the VW511.00 spec. Since then I did a 3 day HPDE at Virginia International Raceway and over 1,000 miles driving back and forth. I will have the oil changed again now, and then will change it every 5,000 miles or after every 2 HPDEs. This will be done at my independent shop without resetting the maintenance interval, I will go to Porsche for the annual oil changes - the first one is included of course but I also bought a 3 year maintenance plan. Here is the Blackstone Report from my first oil change. Reading the tea leaves, maybe the oil change wasn't necessary, but like others have said, engines are expensive, oil is cheap. Also, the car used no oil before the first oil change, and hasn't used any subsequently (according to the magical electronic dipstick). I'll get a Blackstone analysis on the next oil change, after that I'm not sure if I'll keep doing it, but it's only $30 a pop.
Thanks, are you referring to the cSt or SUS viscosity, or both? I think I'll be seeing frequent oil changes, my schedule will be every 2 HPDEs or 5,000 miles, whichever comes first. I usually do a few HPDEs every year, between 2 and 5. If I stay on the low end of HPDEs my miles should be less than 5,000 a year.
I do a yearly oil change, regardless of mileage. I typically do 1500-2k miles. In general, before winter is better than in spring if you're storing so that it isn't sitting with dirty oil. But that's just repeating what I've heard and it does make sense to me.
I also like doing a yearly oil change because it gives a chance for the rest of the car to be inspected and catch anything early so I'm minimizing the chances of needing a repair in the middle of the summer/driving season.
Larry Cable (11-15-2022)
Only a fool would change their oil at 1,500 miles when the break in is complete. Zero evidence it is beneficial. I changed mine at 1,500 miles when the break in was complete. I am the fool.
slilley (11-13-2022)
Eh...except in this case, there is an owner's manual written with the help of Porsche engineers who say every 10k. Not really an "opnion".
