GT4 Tune Question
I am growing to be 'OK' with the drone that occurs between about 1800 and 2500 RPMs with my current exhaust setup. It is obnoxious, but I throttle through it when accelerating, and just suck it up when slowing down to a stop. It is the price I pay to enjoy the epic JCR tone coupled with Dundon headers/OAPs.
What is worse than the drone is the BOOMINESS that exists at idle - anytime I am at a stoplight, which seems like all the time now that it exists.
I say ‘boominess’ because I do not think it is drone . . . but is even MORE annoying because I cannot escape it when stopped. Someone can correct me if wrong, but stock idle seems to be about 1K RPM, give or take.
Is it possible to get a tune that bumps the idle to, say, 1200-1400 RPM? It would not be the end of the world if the tune request came with a slight bump in TQ/HP, but that is NOT why I am interested in a tune.
I am in PDK manual mode 100% of the time with the Race Pipe because automatic mode seems to inconveniently settle in the ‘drone zone’ with every gear - excruciating, even with PDK/SPORT button activated.
The only occasion I currently have for PDK automatic mode is highway driving. Along the same lines as above, I would like to move the RPM settling point for automatic mode to the ‘right’ (higher RPM) so that it is more aggressive, in general, and settles outside (above) the drone zone. If aggressive enough, I might even find automatic mode to be occasionally enjoyable outside highway cruising?
Avera
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Avera
Avera
Avera
Avera (10-24-2022)
Avera (10-24-2022)
Received 3,433 Likes
I have what many would say is a loud/aggressive Soul exhaust and mine is pretty tame at idle...are you saying yours it too loud at idle? Did it change after the exhaust changes?
Yes, at idle (e.g., stoplight) the 'boominess' is intense.
Stock exhaust acoustics were stock exhaust acoustics.
Dundon headers/OAPs with OEM rear box was pretty much like stock exhaust below 4-5K. When the valves opened, the decibels went through the roof, which I loved . . . I am just not a fan of the OEM rear box tone.
Replacing OEM rear box with Race Pipe made everything insane, both good and bad. . . . I described the bad in original post, including the 'boominess' at idle. I do not mind LOUD, per se. I mean, my setup is practically straight-piped.
The 'boominess' at idle, however, is just mind rattling. It is similar to drone experienced at 1800-2500 RPM, but different. Whatever it is - drone or otherwise - I would like avoid it by bumping the idle RPMs up a bit.
Avera
I think I can simplify things down to this . . . I want
1. Idle (e.g., at stops) in to be about 1200-1400 RPM, whether in PDK manual or automatic modes.
2. PDK automatic mode to settle above ‘drone zone’ on shifts . . . again, drone zone is about 1800-2500 RPM so, say, 3000-3200 RPM
If idle were bumped to 3000-3200 RPM it would SOLVE ALL OF MY PROBLEMS. Is idle that high ill-advised?
Possibly mistaken, but I recall my G80C idled in the 3K+ range when Sport Plus was activated so, perhaps, having idle bumped to 3000-3200 RPM could be a ‘one-stop’ solution to all my problems . . . ‘boominess’ at approximately 1K idle AND drone between 1800 and 2500 RPM both eliminated.
If setting idle at 3000-3200K RPM is feasible and not considered detrimental, I would then ask if I could also bump shift point RPMs in PDK automatic mode to the right as well. That would be the absolute cherry on top, as it might allow me to actually enjoy PDK automatic mode for more than highway cruising.
Anyone have any thoughts or experience regarding the above?
Avera
Edit: Cold start settles to about 800 RPM, or so, once cats warm up. I am perfectly fine with that and would not want to change that idle. The 'idle' I am referring to, and want to eliminate, is when I am in a drive mode, whether PDK manual or automatic mode on the roadways and come to a stop. This is about 1K RPM and associated with intense 'boominess.'
@JCR-Porsche
@BGB Motorsports
@Softronic
Avera
@JCR-Porsche
@BGB Motorsports
@Softronic
Too loud at idle, drones terribly in the lower rev range, needing a 3,000+ RPM idle for the sound levels to be tolerable, characterizing your set up as "obnoxious" and "annoying". It sounds like you have a sub optimal exhaust set up a tune can't fix.
85Gold (10-25-2022)
What? 3000-3200 RPM *idle*? Are you driving a V10-era F1 car?
Originally Posted by Avera;18428734
If idle were bumped to 3000-3200 RPM it would [b
SOLVE ALL OF MY PROBLEMS[/b]. Is idle that high ill-advised?
I guess, at some level, everyone on this forum is doing the same. Doesn't seem many are simply content with the car Porsche built for us.
Most all of us enjoy the 'modifying' experience, and I am certainly not the first looking for that 'goldilocks' exhaust solution that best suits ME.
Avera
I think that is a bit of an exaggeration . . . my G80C was far from an F1 car and seemed to settle out near 3K RPM in Sport Plus mode while in ZF8 automatic and manual modes . . . and did not have the red line our GT4s have.
At any rate, I am asking questions. If I had it all figured out I would not have started thread.
Avera
Avera
Avera
Avera
Avera (10-25-2022)
Most would just swap out the exhaust to cure the undesirable characteristics.
Your proposed tune solutions seem like there’d be some significant drivability issues…3000 RPM idle? Case of the cure worse than the disease.
Avera (10-25-2022)
You could be correct
As per my above posts, having 3K RPM 'shift settle' and idling RPM when at a stop was no problem in G80C, and was stock tune in Sport Plus.
I know an S58 is not a NAF6, but I am not sure why 3K RPM would be so detrimental?
Again, I am ASKING questions
At the end of the day I am willing to accept I am barking up a dead tree if such is the case. Above 4K I am in all of my glory and just inquiring if there exists a possible tune solution to attenuate, possibly eliminate, the bad juju that exists in the lower RPM range
Avera
