As I posted in the other thread it’s the current PDLS headlamp modified to have LED lights and not the PDLS+ headlamp. It will look the same as PDLS lamps. It’s a cheap upgrade to get the LED light output though.
No worries more reminding that there’s the other thread that had a lot of chatter about it today. Bummer it’s not the PDLS+ lamp like a lot of you wanted but after seeing the black lamps on my GTS in person the black PDLS housings look great! Very different look than the silver PDLS housings I had on my last 718
I actually agree. The black housing is great. Plus the design of the housing actually ties into the car design and shape better.
My build locks in 3 days and I tried getting my dealer to add this option but the system was not accepting this option. It wont be available till Nov7th apparently.
someone on the PDLS+ thread reports his dealer was able to add this 🤷♂️
May be because that person's build locks in 3 weeks. Mine locks in 3 days and this option is not technically available until Nov 7th. I will ask my dealer to try to add it again today.
Was also told the same. Looks like it’s a firmed up base light for this guy. My order locked last week so it was a stretch I would have been able to do it anyway.
I wonder if this version will be a plug in play swap unlike the PDLS+ swap that isn’t.
Based on the fact it doesn’t have the high beam assistant and windshield mounted camera as with PDLS+, it may well be a much simpler retrofit.
I'd personally option the black Xenon's over the new LED option... they look better IMO. If they have a black housing option with the LED's then it's a no brainer...
The configurator also doesn't allow for the painted washer nozzles with the LED option... Glitch?
