PDK Question
What you are describing was initially called PDK-S (for sport). It was introduced in the 991 GT3 and has been used in every PDK equipped GT car since then.
Much better programming than the standard PDK, which is brilliant.
So yes, it's normal.
Put it this way- I talk MAD **** to my brother, all the time. But I also give him sage advice and call him out when he needs it. He still calls me every single day lol.
FWIW the PDK tuning in my wife's 95B.2 Macan S is abysmal. Taking off is "ok", but the tuning in Sports mode is pure trash, and has been since I bought it new. It's now got 20k miles on it and I'm REALLY hoping the PDK tuning in the 95.B GTS is as good as reviewers say it is (hoping to match or beat the feel of the RS5, as it's the same engine...)
Back to the GT cars, I suppose in traffic the "creep" is beneficial... but I'm sure I'd get used to not having it. Maybe there's a compromise in the non-GT cars where it's assumed they'll be spending far more time in traffic than GT cars? It can't cost any more to distribute the "GT car tune" than the "non GT car tune"... and also I'm assuming the aftermarket can resolve some of this?
Yes, the Cobb PDK tune has the option to remove the PDK creep in non GT cars. That change is also packaged along with reversal of the shift direction when using the center console shifter like the 911 GT cars (pull back to go up in gears) as well as make the double paddle pull neutral mode also work like the GT3. GT cars go into neutral when you pull back both paddles and hold, then drops back into gear when you release. Non GT cars are a "click on click off" of both paddles to go in and out of neutral.
You can do this with the GT car paddle neutral method:
https://www.thedrive.com/news/30044/...che-911-gt3-rs
So, bear with me, as I thought I had this figured out, but now question my understanding
I have not had my 718 GTS PDK for about two years, but my recollection is that it worked precisely the same as my 718 GT4
Namely, in manual mode, GTS did not creep forward and it rolled back when at a stop on inclines. I have never tapped the paddles to throw it into neutral, as I never even use the paddles (only the shifter)
I rarely used automatic mode in my GTS and probably even less so in my GT4. I could be mistaken, but do not recall either creeping forward or rolling back in automatic mode?
So, I do not understand the difference between GT and non-GT PDK? My GTS and GT4 PDK SEEM to work exactly the same.
Any clarification would be appreciated.
Avera
Avera
Avera
Avera
Avera (10-03-2022)
I think that's where the confusion lies. I believe OP is specifically talking about Automatic mode. I mean hell my Veloster N DCT in manual mode doesn't creep forward and so I think that is really the common characteristic of a DCT. However how the PDK acts in Automatic mode is where the difference may lie.
Since I have rarely ever used PDK automatic mode, my recollection on its behavior between the GTS and GT4 could be mistaken
So, with specific regard to automatic mode, GT cars do not creep and will roll back, while non-GT cars will creep and will not roll back
Manual modes function the same between GT and non-GT cars with respect to creep and roll back
Is my understanding correct?
Avera
I just got a 2021 GT4 with PDK transmission. I have had a 2017 991.2 GTS also with PDK since it was new. The 991.2 transmission acted like a normal auto when not driving. The transmission always felt "engaged" in D and R. Take your foot off the brake in D and it might creep forward a little bit. On the GT4 trans, it seems more like a normal clutch type. When at a standstill, there is no movement forward and it seems to need a brisk step on the gas to get moving. Not really a problem - just different from the 911.
Those of you with PDK - how "engaged is the trans? On a slight incline, with it in D, will it roll backward?
And using the center console lever is forward to go up a gear and pull back to go down in gear.
Cobb would have no reason to offer this change in their tune, if the 981 models already worked that way
That could explain why there is so much confusion and different experiences in this discussion if everyone is assuming that their current model works the same as everyone else’s
manifold danger (10-03-2022)
Well thanks for all of the answers and discussion. Seems that the GT cars, when in automatic mode, don't creep and the transmission feels like it is in neutral when stopped. I feel better now..
Edit: Thanks to TXShaggy's correction - the following is only on the non-GT models. See more details on the next two posts.
Here's some more clarifications regarding rolling backwards with the PDK when stopped.
- The PDK's hill hold only comes into play when the incline is 5 degrees or greater and only after the vehicle comes to a full stop with the brakes applied.
- Hill hold can be forced to activate regardless of the angle by "quickly flooring the pressed brake pedal while the vehicle is stationary" (quoted from the Good-To-Know app)
- There is a HOLD light that activates on the speedometer gauge if you aren't sure if it has engaged.
Avera (10-03-2022)
Hold works on GTS and below. GT cars have Drive Off Assist, Hold light will never illuminate.
There is no GTK app for 718 GT cars, although there is some general good stuff that applies to all 718s.
So, I just went out for a short drive on the hills nearby and double-checked. On my GT4 I do get a brief hill-hold on steeper uphill angles but it releases after about 1 to 2 seconds. It seemed to be only ones that probably exceeded 5 degrees. It appears to be called "Drive Off Assist".
But you're right, I never see a hold light and the hard/quick press doesn't cause a hold on more gentle rises.
Well, Doh! That's Good To Know . I guess I misremembered some of that from my prior C2S. Thank you for the gentle and polite correction!
It’s been an ongoing discussion for a couple years.
Check out the thread a few down.
Routine confusion in here between GT and GTS equipment/options.
I don’t mind Drive Off Assist, it’d be better if there was a light to let you know to be patient.
StormRune (10-04-2022)
They must’ve changed the logic on the 718 model then, because a 981 creeps even in full manual mode. This has nothing to do whether using auto or manual mode.
