Adaptive Sport Seats Plus (18-way) with Memory Package - That's my build description
So, for the Spyder and GT4, we get the 18 way seats with all the functions, but obviously, the memory does not function due to 1) the door straps as well as 2) no space for the memory seat physical buttons in the door as a result.
But.... Just wondering if there is any way to use the available buttons on the center counsel for these functions, and wire up the seats? Anyone ever think about this idea or even try it? It looks like there are three free spaces in the center counsel:
Possible, maybe. Easy, no!
Those center buttons are sending LIN bus signals to the front A/C Module, that then communicates through CAN bus to the Gateway Module. I suspect the normal memory buttons comm in LIN bus into the Comfort Module that then comms to Gateway through CAN bus. With tons of custom coding and reflashing of modules, maybe you can do it. Likely easier ways.
Ken in San Diego (09-23-2022)
In theory with global platform production of making production easy for all regions/options there is a chance this is somewhat easy.
Does every car get the seat memory module? My guess is 50/50. It might be standalone or it might be built into another common module. Finding out that would be step 1.
Does every car get the harness with the wiring to the door? Likely. Often cars all get one harness, or there is only 2 or maybe at most 3 different options for a harness which often is based on date more so than options packs. I'd be surprised if the harness didn't have the right wiring on it but it would be somethign that needs to be verified.
If the car has the module already, and the harness already it should just be a matter of extending the wiring to wherever you want htem, buying extra buttons you need for the center console, wiring it up, and potentially then the hard part becomes activating the option in the computer as it potentially is disabled. On a bmw activating disabled options is generally pretty easy as there are apps that give you access to enable or disable stuff, but on a Porsche that could be a nightmare. You'd need to look into if anyone has messed around wiht that stuff and made it available or user friendly to work with.
We know there are companies that have messed with stuff already to change how stuff is config'ed so possibly asking them directly if it's doable wouldn't hurt.
I think OP would be talking about pushing out those dummy buttons and buying new extra buttons and getting those working direct to the OE harness for the seat memory? I have seen people with other cars do that before for various reasons, either activating options or relocating buttons or combining a bunch of buttons into one.
The following 5 users liked this post by Josh_357:
AlexCeres (09-25-2022),
jimdillard (09-25-2022),
Ken in San Diego (09-23-2022),
Larry Cable (09-25-2022),
Zhao (09-23-2022)
Thanks everyone for your perspective and information. Seems worth exploring with a Porsche dealer. If all the wiring and memory modular is already in place, seems “doable”.
Very interesting, that diagram explains a lot. I was definitely outdated on how buttons work. That means that center console buttons are likely one big closed unit pack then so it won't be like older cars where you can push blanks out and add buttons. That rules out adding buttons, and sounds like it also rules out buying the door switch and retrofitting a solution in the center console using that.
The only 'maybe simple' option sounds like buying the door switch + door harness if it's different and converting to handles if the rest of the car is the same, and someone is able to turn that option on or update the module that controls it.
I heard of dealer programming PSP off, changing exhaust….etc.
What you desire I think they won’t touch. You will need to seek out an indie for this type of mod.
JMHO.
