Exhaust tips
The following 2 users liked this post by KelvinC:
Alan C. (12-19-2023),
Larry Cable (09-09-2022)
Correct, the awesome looking Akra tips will only work with the Akra slip on. I did a lot of research on this before I purchased both. Thankfully the slip on provided a great sound and significant weight savings. Unless someone has developed an after market adapter, I believe this is still the case.
Some have adapted the Akra tips to stock, Soul, and other exhausts by using aluminum tape or very thin aluminum flashing. The Akra tips are larger than stock circumference and the collars that come with them don't tighten then anywhere near enough without the use of some kind of gap filler like the aluminum mentioned above. I realize there are a lot of OCDers out there who would never consider such a thing but it is possible. I love the look of the Akra tips but not a big fan of the slip-on Akra exhaust, apart from the price it seems to sound a lot like stock, JMHO. I may try them using one of the above mentioned techniques, will post pics if I do.
luft (12-25-2023)
Received 3,456 Likes
In my final decision process I was feeling a little guilty hoping that I could fit the Akra tips on the OEM exhaust, primarily because the Akra tips have their logo on them indicating one also has the slip on, or full Akra system. Somewhat similar to, but not quite as bad as having a fake Rolex. 😬
@Larry Cable , @Kgoheen , @Regul8415 and anyone else with the Akrapovic slip on, do you have a valve controller installed?
My current setup on my Cayman GTS 4.0 is Soul valve controller with valves always open, Akrapovic slip on, and everything else stock but I'm finding it a tad bit too loud for my tastes. Good tone though. Wondering if I should try the stock valve operation with the Akrapovic slip on.
nintendo_usa (09-10-2022)
The following 7 users liked this post by SlickxAC:
alwaysdriving (04-25-2024),
AtoB (09-10-2022),
dmboone25 (10-12-2022),
MaddMike (09-10-2022),
nintendo_usa (09-10-2022),
and 2 others liked this post.
The following 2 users liked this post by Regul8415:
The following 2 users liked this post by MaddMike:
greengobln (09-21-2023),
UncleDude (09-10-2022)
Like the sound of the Kline exhaust, but the Akrapovic tips are THE best, so it is pushing me back towards an Akrapovic. Had Akrapovic on my last 2 cars and was very pleased. Their diffuser is more refined than the OEM Spyder/GT4 version too.
Larry Cable (09-10-2022)
