718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
GT4RS rear diffuser aero fins
Old 08-31-2022 | 04:42 AM
  #31
808c2s's Avatar
808c2s
Originally Posted by Shawn Hong
dont have the screws yet but just did a brief test fit.
Looking good
IRM (08-31-2022)
Old 08-31-2022 | 04:56 AM
  #32
Shawn Hong's Avatar
Shawn Hong
Originally Posted by 808c2s
@Shawn Hong :From corner to center of 1st hole is 1.5"
thank you
Old 08-31-2022 | 06:40 AM
  #33
Zee Germanz's Avatar
Zee Germanz
I've bought the fins too. There are 3 bolts / screws that attach each side to the diffuser, one hole where it appears they attach to an existing screw fixing on the rear bumper, but I can't work out whether the holes marked in red are also used to fix it to the bumper (they don't have screw fixings preinstalled).
Old 08-31-2022 | 07:25 AM
  #34
Zee Germanz
It would be awesome if you could give the measurements in millimetres for the arrows marked in red below (centre of hole to outer edge). This would really help me when I fit the side blades.
Old 08-31-2022 | 08:59 AM
  #35
TDT's Avatar
TDT
From the look of them - i'm not so sure those red circled holes that are used for attachment - unless it you be from other inside of the bumper down into these holes - but the don't look threaded at all.
Also from the other side... are there corresponding holes to screw through?
Old 08-31-2022 | 09:09 AM
  #36
Zee Germanz
There’s no thread in the holes circled in red. I was wondering if they were for ‘push rivets’ from inside the bumper lip.
I don’t believe there are any parts on the Porsche system that correspond with those holes, though I may double check. Just odd why the holes are there.
Old 08-31-2022 | 06:13 PM
  #37
MechEngr1287's Avatar
MechEngr1287
Good discussion here folks! I definitely plan to add some of the GT4RS Aero bits to my car as more become available to order down the line.
Old 09-01-2022 | 03:39 AM
  #38
808c2s's Avatar
808c2s
Ah, sorry, did not see this until now. I already gave my dealership the rear diffuser kit for installation while the Spyder is getting a warranty work. If you just drill the first hole, the rest can be drilled by using the side blade holes as template. So the first hole is 4cm or 3.81cm (1.5") from the corner to center of hole.
Zee Germanz (09-01-2022)
Old 09-01-2022 | 02:20 PM
  #39
TDT's Avatar
TDT
Screen grab from the MR JWW video where they have stripped down and 'repainted' their GT4RS.
The Screen grab shows the underside of the rear bumper... there are not additional screw/affixings to the rear bumper itself for the rear aero fins... looks like they are just screwed unto the plastic diffuser valence(x3) and re-use the single bolt towards the front. Or there are addition fixings... its on the inner lip.
The following 2 users liked this post by TDT:
IRM (09-01-2022), Zee Germanz (09-01-2022)
Old 09-01-2022 | 03:58 PM
  #40
Zee Germanz
Nice one, good spot.
Old 09-01-2022 | 08:27 PM
  #41
Bob Z.'s Avatar
Bob Z.
Just a thought but maybe one bolt and 3M tape will suffice? However, I would prefer to take the rear valance off and drill 3 holes in it as a better way to attach them.
Old 09-02-2022 | 01:14 AM
  #42
Shawn Hong's Avatar
Shawn Hong
installed and secure.
The following 5 users liked this post by Shawn Hong:
Frank Torres (09-05-2022), IRM (09-02-2022), Ken in San Diego (09-02-2022), MechEngr1287 (09-02-2022), rp2000r (09-02-2022)
Old 09-02-2022 | 03:00 AM
  #43
sin911's Avatar
sin911
Nice! So did you just use 3 screws per side? How did the winglets/fins attach to the current diffuser? No issues I assume
Zee Germanz (09-02-2022)
Old 09-02-2022 | 04:16 AM
  #44
TDT's Avatar
TDT
Subtle change but looks complete now. Never understood why it wasn’t like this from day 1 anyway.
Old 09-02-2022 | 09:01 AM
  #45
Zee Germanz
Nice!
Can you share your install procedure?
Did you remove the diffuser and is it a ball ache to do?
Are the side blades/fins a direct fit to the GT4 diffuser i.e. the only difference being the RS diffuser has the holes predrilled?
Quick Reply: GT4RS rear diffuser aero fins
