Coding options and features for 718
#107
@TubaFreak You need to enable Auto Time Sync to the cluster selection with PIWIS.... See post #163 in this thread; https://rennlist.com/forums/718-gts-...it-diy-11.html
#108
Z06jerry (03-13-2024)
#109
#110
@isthar, @TubaFreak and others: To get the GPS autotime for my gt4 without factory Nav, I use post 893 of the OEM Navigation Retrofit DIY thread to get the Nav to show on my cluster with the X-431. Then I check autotime to GPS in the cluster. Not sure if the step in post 893 was necessary but I did that first.
Now a question to those experts on the X-431, when I install the GPS antenna, the PCM still say that the GPS antenna is not there. Do I need to change the code in the PCM so that it say the GPS antenna is there? If so can we do it with our X-431?
#111
Do you have needles lighted all the time - I believe the only way is to run full Scandinavian DRL setting?
Ended up getting the Launch X431 CRP919E version since its a lot cheaper than the top end, there's a newer CRP919EBT (wireless bluetooth) that some might want to consider as well.
#112
I realize this is old, but haven't found an answer. Does anyone know if it's possible to change the sport exhaust valve opening to something other than 3800 rpm....or is this a hardware issue?
#113
Nope, this is controlled by a relatively complicated map in the DME that is not configurable in PIWIS. Tuners like APR, M-engineering, etc... can change it.
Treemagnet (08-06-2024)
#114
Won't allow me to set anything beyond 255, so I did that for both first operation and next operation.
FRONT END ELECTRONICS > Coding Value - Exterior Lights, DDL with marker light = Yes
neteng101 (08-07-2024)
