Spyder: a trick to top-drop double click?
You are supposed to be able to double click (and hold) the unlock button to get the top to unlatch and the boot to open, but it only seems to work 50% of the time. Have others experienced this? What am I doing wrong? Is there a technique I am missing?
Larry Cable (08-13-2022)
The open top feature works in NA. The close feature is not (at least in US).
To open the top, the key definitely does not need to be in the ignition. The dance is supposed to be, with key fob:
Press unlock and release
Press unlock and hold until roof unlatches and boot opens.
This does work, just not reliably for me.
Top
The North American cars do have this. The only feature us North Americans can’t be trusted with apparently is the feature to hold the lock button to latch the top from outside when closing the top.
The following 3 users liked this post by ariazad:
Regardless of command the FOB seems to be very position/range dependent. Sometimes standing next to the car have to push lock/unlock couple of times for function.
WRT to roof; unlock followed by two more quick unlocks and hold the last unlock always works for me.
Obviously I didn’t RTFM.
So Tx, you triple push (holding on the last)? Sounds like unlock, brief pause, dbl unlock and hold? This works reliably for you?
I only know about this from scouring YouTube for spyder content while I waited for my car.
Adrift (08-13-2022)
Received 3,461 Likes
I have found that just pushing unlock and holding it works (most of the time), when I am right next to the car.
I tried this for the first time this morning, and it worked for me.
The following 2 users liked this post by dmboone25:
Adrift (08-13-2022),
Larry Cable (08-15-2022)
